* Two concrete enclosures, each with more than 1m3 of volume, with a special external and internal design, without any damping material inside, where are fitted indepentdently two woofers (10" x 2) and a subwoofer (18"). The speakers cones selected for the reproduction of the mid-bass, mid, mid-treble, treble and ultra-treble frequencies (up to 10 per channel) are anchored to a 25 cm concrete wall. All these speakers units come from well known brands in the audiophile world: Focal, Dynaudio, Seas, Sequerra y Mc Kenzie. All these speaker cones have been selected according its frequency response, efficiency and the the power amplifier that drives them.
Zestaw głośników, jaki w danej chwili gra, jest wybierany za pomocą jakiegoś programu na kompie (to nie jest tak, że wszystkie drą japę):
Operating the system
As you can see all the components used in this system are top quality. Ramón is specially proud of the OmniDrive BSS FDS-388 active filters, that he controls using SounBench software with his computer: "With this device I can control, in real time and with absolutely precision -it is a digital filter- with what frequencies, at what level, in what phase and with what changes in the response curve, is sent the audio signal to the power amplifiers, from which the signal is sent -without any passive component (!!!)- to the speaker. Ramón says that "...only for this reason I would recommend the use of this kind of filters, given that this means an incredible improvement over passive components (capacitors, resistors, coils, etc) and it brings a lot of benefits: dynamic improvement, fastest response, microinformation, etc, etc.
With this system, Ramón can choose between different preset configurations or create new ones, as many as he wants, until find the one best suited for every recording. The number of possible combinations is infinite and he can store 60 of them to use in a future.
