Może ktoś zrobić plik projektu dla TIW300 60 litrów?
Jest już wersja po ENG:
http://www.boxsim.de/
Sypie errorami.
Error: driver 1....
Tak widziałem:
http://diyaudio.pl/content.php/71-Boxsim
I robiłem wszystko co w helpie:
Sypie errorami.
Error: driver 1....
Tak widziałem:
1) Menu "File" -> "New project"
2) Enter number of drivers and amps (1 if speaker is passiv) in the dialog "Project properties" which opens automatically.
Hint: double drivers count as two.
3) Choose every driver in Menu "Drivers and Enclosures", enter card "Driver data" and load a driver from a file. Afterwards enter all data on card "Enclosure & Impedance".
4) Enter outer dimensions of the housing and positions of the drivers in menu "Drivers and Enclosures", submenu "Common outer housing". These dimensions are used to calculate diffraction effects (bafflestep, ..)
5) Enter your crossover network in menu "Amplifier 1", submenu "Edit crossover network". A crossoover network has to contain at least an amplifier output, one driver and two wires between them.
Hint: The right mousekey offers some functions in the crossover network editor.
6) If you like your results: Menu "File", submenu "Save project as …" hopefully will do what you expect.
Hints for experienced users:
The output window contains up to 9 different cards, some of them with further options. Browse them.
You can add an active filter prior to every amplifier putput in menu "Amplifier ..", submenu "Actice filter ..".
The menu "Edit" covers not only an undo function, but also some functionality to compare two projects.
You can choose up to 6 amplifiers and up to 8 drivers for your project in menu "File", submenu "Project properties".
The standard directories for driver files, project files and for crossover parts can be entered in menu Options", submenu "Directories".
This allows you to separate program and data..
The menu "Extras" contains some calculations based on common formulas from former times when computers were weak or not available.
Drivers can be placed on different baffles if you enter the data on the card "Baffle and Enclosure" in the drivers editor.
The editors for drivers and crossover networks can stay open during a lot of functions. This may save yoou a lot of clickwork if you have a sufficient screen on yout computer.
