PIONEER TS-W251
Parametry:
MAX MUSIC POWER 300W
NOMINAL POWER 120W
śREDNICA 25CM
IMPEDANCJA 4OHMS
DYNAMIKA 92.5dB/W
PASMO 18-4.000HZ
WAGA 4.28KG
Parametry TS
Vas 43,61
Fs 43,4
Qts 0,54
GLOśNIK ZOSTAŁ ZAKUPIONY ROK TEMU OD KOLEGI.BYL MAŁO UŻYWANY.WIĘKSZOŚĆ CZASU PRZELEŻAL W GARAŻU.
STAN TECHNICZNY GLOSNIKA OCENIAM NA BARDZO DOBRY.NIE BYLO ŻADNEJ INGERENCJ W ZAWIESZENIE LUB W INNE CZEŚCI.
W MOMOENCIE PODKRECENIA MOCY NA WZMACNIACZU GLOSNIK ZACZYNA CHARCZEC.TRZSKI SA BARDZO WYRAZNE I DENERWUJACE NAWET PRZY MOCY WZMACNIACZA OKOLO 50W NA I KANAL.
JAKKA JEST TEGO PRZYCZYNA?
CZY DA SIE TO NAPRAWIC? JEZELI TAK TO MOZNA ZROBIC TO SAMEMU?
CZEKAM NA ODPOWIEDZI
Parametry:
NOMINAL POWER 120W
śREDNICA 25CM
IMPEDANCJA 4OHMS
DYNAMIKA 92.5dB/W
PASMO 18-4.000HZ
WAGA 4.28KG
Parametry TS
Vas 43,61
Fs 43,4
Qts 0,54
