KENWOOD KRF-V5020 co mi o nim powiecie ?
Elbląg
Czy to dobry amplituner ? czy ma dobrą jakoś dzwieku czy brakuje mu basu sopranu? jaką ma moc na kanałach ?ile jest wart ?
z ulotki producenta
AUDIO section
Rated power output during STEREO operation
KRF-V7020
(DIN) 1 kHz, 0.7% at 4 Ω .......................................... 100 W + 100 W
KRF-V6020, KRF-V5020
(DIN) 1 kHz, 0.7% at 4 Ω ...............................................80 W + 80 W
Effective power output during SURROUND operation
KRF-V7020
FRONT (1kHz, 0.7% T.H.D. at 4 Ω one channel driven)
.............................................................................. 100 W + 100 W
CENTER (1kHz, 0.7% T.H.D. at 4 Ω one channel driven)
............................................................................................. 100 W
SURROUND (1kHz, 0.7% T.H.D. at 4 Ω one channel driven)
.................................................................................. 80 W + 80 W
............................................................................................... 80 W
Total harmonic distortion ........................... 0.05% (1 kHz, 40W, 4 Ω)
Frequency response
CD ............................................. 10 Hz ~ 60 kHz, +0 dB, –3.0 dB
Signal to noise ratio
PHONO (MM)......................................................... 75 dB (IHF'66)
CD .......................................................................... 93 dB (IHF'66)
Input sensitivity / impedance
PHONO (MM)......................................................... 2.5 mV / 27 kΩ
CD ......................................................................... 200 mV / 47 kΩ
DVD 6CH (SUBWOOFER) ................................... 200 mV / 10 kΩ
Output level / impedance
TAPE REC .......................................................... 200 mV / 2.2 kΩ
PRE OUT (CENTER, SURROUND) ........................... 1 V / 2,2 kΩ
PRE OUT (SUBWOOFER) ......................................... 2 V / 2.2 kΩ
Tone control
BASS............................................................... ±10 dB (at 100 Hz)
TREBLE .......................................................... ±10 dB (at 10 kHz)
wartość rynkowa około 250zł
A ktoś go słyszał co można o nim powiedziec ?:)
---------- Post dodany o 19:48 ---------- Poprzedni post o 19:48 ----------
ja moge go kupić za 200zl oplaca sie?
Z jakimi kolumnami będziesz tego używał? Jak masz kolumny stereo to w tej cenie znajdziesz lepszy wzmacniacz stereo.
Witam mam takie pytanie. Może mię wyśmiejecie. W jaki sposób działają kanały do kolumn w wzmacniaczu 5.1. tak wtyki do kolumn frontowych to sie domyślam że jest jak w zwykłym wzmacniaczu stereo czyli wychodzi z nich pełno pasmo a z centralnych i ty jeszcze dwóch wtyków do głośników też leci pełne pasmo czy niskie częstotliwości są ucięte ?
Zależy od funkcji amplitunera.
W moim Sony STR-DE635 można sobie ustawić czy sub ma być włączony czy też nie, wtedy niskie częstotliwości są kierowane albo na suba albo na kolumny.
Funkcja kolumn SMALL i LARGE też w tym bierze udział.
Ja kupiłem tego KENWOOD KRF-V5020 wie ktoś jak to w nim działa ? Bo chce zakupić komplet głośników do niego ale nie chce tak że jak dam dość głośno to kolumny frontowe będą grać normalnie a efektowe i centralny będą już pierdzieć
Ale jak Ty chcesz słuchać muzyki na wszystkich 5-ciu głośnikach?
Nie ma trybu STEREO + reszta głośników, są różne efekty dźwiękowe takie jak HALL, ARENA itp. i wtedy głośniki tylne i głośnik centralny jest już odcięty od niskich częstotliwości, więc "pierdzieć" od basu nie powinny.
Bas wtedy jest kierowany na suba lub kolumny frontowe, w zależności jak ustawisz.
Tak powinno być w "normalnym" ampli, jak jest w tym tego nie wiem i osoby które go nie posiadały nic o nim nie powiedzą.
to znaczy tak sprzęt bedzie podłaczony do komputera i czasem słucham muzyki i oglądam filmy
---------- Post dodany o 11:37 ---------- Poprzedni post o 11:34 ----------
myślę nad zakupem tego kompletu do tego wzmacniacza http://stx.pl/stx-kd-200-n-5-0-kolor-orzech.html czy to dobry wybór czy może zaproponujesz/cie cos innego ?
---------- Post dodany o 15:45 ---------- Poprzedni post o 11:37 ----------
doręczam zdjęcie tyłu wzmacniacza. http://www.otofotki.pl/img15/obrazki/ll2949_10.JPG do których wtykow podłaczyć kolumny ? a gdzie subwoofer ? a gdzie kabelki od komputera ? posiadam ten subwoofer http://stx.pl/stx-s-250-n-kolor-calvados.html
Co to za dzień....urodziny elektrody i wzięła sobie wolne? :ohmy:
Kolumny z linka się nadadzą, chyba ,że masz więcej kasy do przeznaczenia lub chcesz je zrobić sam. Podłączasz je tam gdzie się powinno, czyli do wyjść amplitunera/ te czarno czerwone wtyki. Wyjścia na suba nie ma, więc podłącz do pre out/ masz w końcu suba aktywnego. Jak kable od kompa? Zależy od ciebie/ połowa tyłu amplitunera to wejścia. Jak ustawisz w kompie wyjście z karty dżwiekowej tak podłączasz do amplitunera/ wyjście 5.1 z kompa który dekoduje dżwięk surround, albo pojedynczym kablem/ w kompie ustawiasz stereo i amplituner ci dekoduje do surround.
Ps. Jest też google. Wpisujesz nazwę swojego amplitunera + manual (instrukcja) i wyskakuje ci http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CC4QFjAA&url=http%3A%2F%2Fmanuals.kenwood.novenaweb.info%2Flanguages%2FNL%2Fsupport%2Fmanuals%2FKRF-V7020-6020-5020.pdf&ei=GwU_UufgFsXP0QXrkICACA&usg=AFQjCNGnOKrum6FiAUngHFXkqGoPnHL_Hw&sig2=QYfn_TNHIuy2wRsG9Yve2w&bvm=bv.52434380,d.d2k
Przecież pisze na wzmacniaczu pod dwoma czrnymi wtykami subwoofer to nie jest do subwoofera?
Tak. O to wyjscie mi chodzilo/ po prostu niektore amplitunery maja takie wyjscie zaraz obok wyjsc na glosniki ( lub maja 2 sub out)/ tu jest ono w czesci pre out ktore sluzy do polaczenia z innymi wzmacniaczami (wtedy amplituner pelni tylko funkcje dekodujaca audio i wysylajaca je na zewnetrzne wzmacniacze.) Z tego powodu ze twoj sub ma wbudowany wzmacniacz to podlaczas je do tego wyjscia tak jak wczesniej napisalem tylko niedokladnie wytlumaczylem/ chodzilo mi o ta oddzielna czesc tylnego panelu opisaną jako wyjscia na glosniki.
