SW1 275-0664 DPDT center-off 6A mini toggle switch
SW2, SW3 275-0663 DPDT 6A mini toggle switch
BP1-2, BP3-4 274-0718 Dual binding post
J1 - J4 274-0852 RCA jacks, gold plated
R1 271-120 8 ohm non-inductive 20W resistor
R2, R3 271-1124 1.175k 2W resistor (four 4.7k 1/2W in parallel)
R4 - 16.2 ohm 2W resistor (four 16.2 ohm 1/2W 1% in series/parallel)
R5 - 4.05 ohm 2W resistor (four 16.2 ohm 1/2W 1% in parallel, see text)
R6 (assortment) 543.2 ohm 1/4W (680 ohm in parallel with 2.7k ohm, both 1/4W 5%)
R7 (assortment) 130.1 ohm 1/4W (180 ohm in parallel with 470 ohm, both 1/4W 5%,)
D1 - D4 276-0565 5.1V 1W Zener diode
BTW jest tu: diyaudio.tk
