Hej,
Może ktoś powiedzieć coś na temat tych tych dwóch monitorów ? Warto dopłacać dla scanów ?
The Piccolo (by Jeff Bagby)
Woofer: SB Acoustics SB15NRX30-08-UC (Frequency Response | Impedance | CSD | Harmonic Distortion | Thiele / Small Parameters)
Tweeter: SB Acoustics SB29RDCN-004 (Frequency Response | CSD | Harmonic Distortion)
"I did this as a Kit for Meniscus. It is one of the better small speakers that I have done. It uses the SB15 and SB29RDCN tweeter. The crossover point at about 2.1kHz with a nearly perfect textbook 4th order L-R crossover and the widest phase tracking I have yet seen in a speaker. The response is exceptionally flat and comes in a vented or sealed version. Mark doesn't have it posted yet, but has already sold some kits anyway. I liked it so much that I have kept the original as my personal set." - Jeff Bagby
vs
EllamXT (by Troels Gravesen)
Woofer: ScanSpeak 15W/8530-K00 (Frequency Response | Impedance | CSD | Harmonic Distortion | Thiele / Small Parameters)
Tweeter: Vifa XT25TG-30-04 (Frequency Response | CSD | Harmonic Distortion)
"The Ellam XT was made around Dec. 2006 and after some two years on the web, this Ellam XT turns out to be one of the most popular speakers on this website - and for good reasons:
- fairly low cost due to the excellent and cheap XT25TG tweeter
- easy cabinet construction and fairly easy crossover layout
- probably the best bass performance on the market from a 10 liter cabinet volume
- 15W has a smooth midrange and a smooth upper roll-off that makes crossover construction easy
- generally high WAF depending on your skills in cabinet making
- I could go on...this 15W driver is a winner. " - Troels Gravesen
Umie ktoś powiedzieć jak te dwa zestawy powinny grać patrząc na dostępne dane ?
Obudowy niedługo będę kończył więc muszę w końcu zdecydować się na jakiś zestaw głośników, projektowanie zwrotnicy samemu raczej nie wchodzi w grę (choć chyba i tak kupie sobie jig-a i pobawię się zwrotnicą z powodu dość nietypowej obudowy) więc muszę wybrać coś gotowego :)
vs
