earthquake balls 15
łódz
Witam , czy ma ktoś jakie kolwiek informację na temat tego przetwornika z 2001 roku ? Szukam głównie danych dot skrzyni
Proszę bardzo. Wszystko czego potrzebujesz by zrobić odpowiednią budke do tego maleństwa :thumbup:
Company: Earthquake Sound
Model: BALLS15
Type: Standard one-way driver
Shape: Round
Piston Type: Cone
Voice Coil: 3 inch voice coil.
Magnet: 90 oz magnet.
Fs = 33.66 Hz
Qms = 8.709
Vas = 3.203 cu.ft
Cms = 0.0141 in/lb
Mms = 9.778 oz
Xmax = 0.98 in
Xmax (parallel) = 0.98 in
Xmax (series) = 0.98 in
Sd = 138 sq.in
Qes = 0.744
Qes (parallel) = 0.372
Qes (series) = 0.372
Re = 3 ohms
Re (parallel) = 1.5 ohms
Re (series) = 6 ohms
Le = 1.737 mH
Le (parallel) = 0.868 mH
Le (series) = 3.473 mH
Z = 4 ohms
Z (parallel) = 2 ohms
Z (series) = 8 ohms
BL = 3.456 lb/A
BL (parallel) = 3.456 lb/A
BL (series) = 6.913 lb/A
Pe = 250 watts
Pe (parallel) = 500 watts
Pe (series) = 500 watts
Qts = 0.685
Qts (parallel) = 0.357
Qts (series) = 0.357
1-W SPL (parallel) = 91.56
