Kupiłem głośniki niskotonowe Tonsil GDN30 /80/60 800W
SZCZEGÓŁOWE PARAMETRY
Specifications
Nominal Basket Diameter
12" / 300mm
Impedance
8 or 4 ohms
RMS Power Rating
400 Watts
Program Power
800 Watts
Frequency Response
25Hz - 4.0kHz
Sensitivity (1W/1m)
94.5dB
Voice Coil Diameter
2" / 52mm
BL Factor
13.3 N/A
Voice Coil Length
19 mm
Air Gap Height
7 mm
X Damage (peak to peak)
25 mm
Magnetic Assembly Weight
6.1 lb. / 2.75 kg.
Mounting Information
Overall Diameter
12.6" / 320mm
Bolt Circle Diameter
11.77" / 299mm
Baffle Cutout Diameter-
- Front Mount
11.26" / 286mm
- Rear Mount
11.02" / 280mm
No. Of Mounting Holes
4
Volume Displaced By Driver
0.14 ft3 / 4 Liters
Overall Depth
4.92" / 125mm
Net Weight
7.81 lb. / 3.55 kg.
Shipping Weight
8.81 lb. / 4 kg.
Materiale
Basket
Pressed Sheet Steel
Cone
Paper
Surround
Rubber
Voice Coil
Copper
Magnet
Ferrite
Thiele-Small Parameters
Resonant Frequency (fs)
19Hz
Impedance (Re)
6.6 / 3.6 ohms
Coil Inductance (Le)
1.0 mH
Mechanical Q (Qms)
1.89
Electrical Factor(Qes)
.44
Total Q (Qts)
.36
Comp. Equivelant Vol. (Vas)
4.77 ft3 / 135 Liters
Voice Coil Overhang (Xmax)
10.0 mm
Reference Efficiency
1.2%
Displacement Volume
340 cm3
Low Freq. Response: Bass Reflex Cabinet-Vb=90L, Fb=38Hz
Pomóżcie mi znaleźć odpowiednie głośniki wysokotonowe i wyliczyć wielkość kolumn, oraz dopasować zwrotnice!!!
Z góry wielkie THX!!!
Specifications
12" / 300mm
Impedance
8 or 4 ohms
RMS Power Rating
400 Watts
Program Power
800 Watts
Frequency Response
25Hz - 4.0kHz
Sensitivity (1W/1m)
94.5dB
Voice Coil Diameter
2" / 52mm
BL Factor
13.3 N/A
Voice Coil Length
19 mm
Air Gap Height
7 mm
25 mm
6.1 lb. / 2.75 kg.
Overall Diameter
12.6" / 320mm
11.77" / 299mm
- Front Mount
11.26" / 286mm
- Rear Mount
11.02" / 280mm
4
0.14 ft3 / 4 Liters
Overall Depth
4.92" / 125mm
Net Weight
7.81 lb. / 3.55 kg.
Shipping Weight
8.81 lb. / 4 kg.
Materiale
Basket
Pressed Sheet Steel
Cone
Paper
Surround
Rubber
Voice Coil
Copper
Magnet
Ferrite
19Hz
Impedance (Re)
6.6 / 3.6 ohms
1.0 mH
Mechanical Q (Qms)
1.89
.44
Total Q (Qts)
.36
10.0 mm
1.2%
Displacement Volume
340 cm3
