Jeden jest mój, drugi kolegi
AU-07
Effective output
(10Hz - 20kHz, both channel simultaneous operation) 110W+110W (6ohms)
90W+90W (8ohms)
Power dissipation 280W
Weight 34.0kg
907MR
Effective output (10Hz - 20kHz)
Both channel simultaneous operation 190W+190W (6ohm)
160W+160W (8ohm)
Power dissipation 400W
Weight 33.0kg
Reszta parametrów wspolnych
THD (at the time of an effective output) 0.003% or less (8ohm)
Cross modulation distortion 0.003% or less (8ohm)
Dumping factor 150 (8ohm)
Frequency characteristic (1W) DC-300kHz+0 -3dB
Input sensitivity/impedance 1V / 5kohm (1kHz)
SN ratio (A network) 120dB or more
TIM distortion (Sawtooth) Below a limit-of-measurement value
Slew rate 200v/microsec
Rise time 0.5microsec
he frequency characteristic (1W) Phono man month: 20Hz-20kHz�}0.2dB
compact disk, Tuner, Line, Tape/DAT1, and 2
C-300kHz+0 -3 dB
SN ratio (A network) Phono man month: 90dB or more
Phono MC: 75dB or more
compact disk, Tuner, Line, Tape/DAT1, 2:110dB or more
