Q1. No sound. Daphile seems to recognize audio device and play music
to it but there is no sound?
A1. In most cases this is related to the "Mixer Controls" settings of
the audio device (Settings -> Audio Devices). User might have to enable
some controls there in order to unmute the sound.
After trying out daphile on a Pentium Dual-Core E5300 Asus system, I decided to try it out on an old Pentium 4 system (P4/3.2GHz). It is a HTPC sort of machine with non-standard KLOSS mainboard, badged Dreamsys, and a C-media CMI9880 audio chip (a high-end chip way back when, with native 24bit/192KHz ADC and DAC).
daphile (32-bit) worked fine straight away, but alas, no sound. Trying out a lot of settings incl. alsa did not help. Furthermore, the system did not give any indication that something was wrong, the music player indicated that songs were playing but no sound at all.
I then switched player from Squeezelite to SqueezePlay, reboot, and hey presto, there was sound! All the way up from 16bit/44.1KHz to 24bit/192KHz excepting multiples of 44.1KHz (i.e. 88.2 & 176.4). Hence, the audio driver (or player?) does not seem to check the different sampling rates supported by the on-board DAC and transcode accordingly. OTOH, the CMI9880 is a quirky chip; I remember all sorts of problems with it under Windows at the time, requiring a number of driver updates and none was completely glitch-free.
Druga -> jeszcze nie sprawdziłem ale wydaje się być protezą a nie rozwiązaniem problemu. Jeszcze nie wiem jak ale zmienić ale wgryzę się w temat
Nie wiem czy to ma jakieś znaczenie ale w logu USB Audio porównując do amanero nie znalazłem trybu stereo tylko mono.
