Two years ago, LKS audio will be built Amanero of this usb module in their own first decoder MH-DA002 with a USB interface, and the continued use of this excellent performance usb module in the
new and old works get a lot of new and old customers appreciate. However, there are some very high user request some views, such as a customer believes that the decoder when using the computer usb port connection,
use and reproduction of sound or digital turntable professional cd player is connected sound compared to slightly rough, lack of sophistication, instrumental texture slightly worse shape, and so on.
Thus, LKS virtue and Amanero company has always been a good working relationship, after Amanero authorized, specially launched an exclusive high-end version of Amanero combo384 module.
High-end version of the module using six sets of high precision ultra low noise voltage regulator for each separate part of an independent power supply to ensure that each member can each get a stable power supply and less subject to interference from other devices.
While the wiring line optimization.
Actual comparison can be found, the module after this change, even if still using computer usb port to take power in the manner that the reproduced sound quality has improved significantly compared to the original:
the overall sound imaging and more stable (the original somewhat flighty), high frequency more delicate moist (original a little rough, frizzy), the instrument becomes strong physical sense,
sound texture improved significantly, increase the density of low-frequency, low frequency dive in order to improve cohesion.
The new module, in order to improve playability, specifically the two audio clock recovery uses a separate power supply cable, so that the modification can be an independent power supply when the crystal and then a separate power supply. Further improve quality.
main feature
1. Italy Amanero authorized official firmware, using the method is completely consistent with the original
2. The ultimate design optimization, improve performance
3. The six independent power supply design, 9uVrms ultra low noise regulators.
4. Ultra-low noise active clock
5. All capacitors, beads are imported TDK, Murata Murata, thick sound resistance
6. The original and official combo384 replace the original hole in situ installation, the overall width is widened, the same length. Length 68mm, width 47mm. Thickness of 1.0mm.
7. Process best FR4 immersion gold plate, materials, technology surpassed the original module
