Cześć. Mam zamiar stworzyć subwoofer oparty o Kappe Pro 15 od Eminence.
Podpowiedzcie jaki wzmacniacz kupić do takiego glośnka? Wzmacniacz musi wyciągnać 100% :d
Specyfikacja
Specyfikacja
KAPPA PRO-15LF-2
SPECIFICATION
Nominal Basket Diameter 15", 381mm
Nominal Impedance* 8 ohms
Power Rating
Watts 600W
Music Program 1200W
Resonance 35Hz
Usable Frequency Range 38Hz-1.8kHz
Sensitivity*** 97.8
Magnet Weight 120 oz.
Gap Height 0.375", 9.53mm
Voice Coil Diameter 3", 76.2mm
THIELE & SMALL PARAMETERS
Resonant Frequency (fs) 35Hz
Download PDF Spec Sheet
Download PDF Cabinet Design
DC Resistance (Re) 6.5
Coil Inductance (Le) 1.40mH
Mechanical Q (Qms) 7.3
Electromagnetic Q (Qes) 0.32
Total Q (Qts) .30
Compliance Equivalent Volume (Vas) 198.8 liters / 7.0 cu.ft.
Peak Diaphragm Displacement Volume (Vd) 507cc
Mechanical Compliance of Suspension (Cms) 0.20mm/N
BL Product (BL) 21.6 T-M
Diaphram Mass inc. Airload (Mms) 102 grams
Efficiency Bandwidth Product (EBP) 112
Maximum Linear Excursion (Xmax) 6.7mm
Surface Area of Cone (Sd) 856.3cm2
Maximum Mechanical Limit (Xlim) 18.0mm
