  • jaskiniowiec
    replied
    2sc4685 and 3964 - on the market are sold exclusively fakes.
    For temperature compensation 2SD1694
    http://www.kashinoki.co.jp/page021_2m.shtml
    100 proc original.
    Counterfeiting of ebay also work.
    your choice
    Zostaw komentarz:
  • dzwiedziu
    replied
    They were checked 2sc4685 or 2sc3964 so I do not know how the system will behave with the BD139.
    Zostaw komentarz:
  • platon.rado
    replied
    Q25 is BD139..it is good???
    The amplifiers are not thermally stable.Bias arbitrarily increases.Of 100 mA to 120 mA for 10 minutes.VR1 it works.
    Zostaw komentarz:
  • dzwiedziu
    replied
    And more specifically?
    Zostaw komentarz:
  • platon.rado
    replied
    Hello boys,amplifier plays perfectly, but bias is dependent on volume.You do not know what it can cause ???
    Zostaw komentarz:
  • platon.rado
    replied
    amplifier works..thanks guys.DC offset 3mV.Thanks Grzegorz
    Zostaw komentarz:
  • platon.rado
    replied
    GND A, belongs to auxiliary power supply..oki thanks
    Zostaw komentarz:
  • platon.rado
    replied
    I have new pcb version 2016.I have two gnd.GND A and GND B.GND B is the main.But what is GND A...Thanks guys.
    Zostaw komentarz:
  • dzwiedziu
    replied
    Zamieszczone przez platon.rado Zobacz posta
    GND is ok???
    Zostaw komentarz:
  • .3lite
    replied
    If you connect it on the main capacitors (usually between them) then the return current of the signal path will be modulated by the charge current of the main capacitors resulting in 50 Hz tone and its harmonics. It's hard to tell whether it will be audible or not since it depends on the location and the flow of the current, but it will certainly degrade the overall performance of the amplifier.
    The best option to solve this issue which in fact should have been solved on the PCB (the design is quite crappy since the PCB itself should act as the main ground point for the signal and the output) is to create a standalone ground point after the main capacitors to avoid modulations caused by the charge current.
    Also, please use the following uploader for your images:
    http://diyaudio.pl/uploader.php
    Click on the "diyaudio.pl" rectangle (a default container if you will) and use option of "Dodaj pliki" to select desired files in order to upload them ("Załaduj obrazki"). Below all of that you will find your images which you can use on the forum.
    Zostaw komentarz:
  • platon.rado
    replied
    GND is ok???
    Zostaw komentarz:
  • platon.rado
    replied
    tomorrow test
    Zostaw komentarz:
  • platon.rado
    replied
    Thanks
    Zostaw komentarz:
  • dzwiedziu
    replied
    D18,19,20,20 not standard.
    R29~32, R59,60 fuse resistor or metal film 0,6W.
    Zostaw komentarz:
  • kolmen
    replied
    It would be better use fuse resistor , but You can mount standard resistors a same value
    D20,D21 are HZ153L
    Zostaw komentarz:
  • platon.rado
    replied
    Hello guys.
    R29-32 R59,60 must be fuse resistors ???
    And value D20,21 ????
    Thnaks
    Zostaw komentarz:
  • Darodff
    replied
    Hej
    Odkupię trafo plus zasilacz do E-450 Ewentualnie komplet drobnicy do niego
    Zostaw komentarz:
  • Birofil
    replied
    Cewka 1uH w zabezpieczeniu jest wystarczająca czy lepiej nawinąć większą?
    Zostaw komentarz:
  • jaman7
    replied
    Dzisiaj była przygoda z e450, znaczy odpalam rano tak aby coś grało, mija kilka minut wyłącza się, zabezpieczenia zadziałały, no drugi i trzeci, mierze czy nie ma dc na wyj , i okazało się ze na jednej powoli narastało DC do zadziałania zabezpieczenia. A całym złoczyńcą był kurz który nazbierał się przez otwory od góry obudowy.
    Zostaw komentarz:
  • Trol.
    replied
    Niestety nie pomogę. Nie wiem. :unsure:
    Zostaw komentarz:
